- Sep 28, 2009
- Concord, NC
I've started having a peculiar problem with my XJ and was hoping you guys could help me troubleshoot. The problem started last weekend at Mountain City, but has gotten much worse.
When I step hard on the gas, to the floor, I can hear the intake gulping in the air and the engine revs but it just has no power at all. In 2WD it slows almost to a crawl while going up the small hills on the state roads at URE. In 4-lo I can barely spin the tires when trying to climb up the rocks.
Here's what I've done recently. Replaced fuel filter prior to the problem to help shorten the starting times. Takes at least 5 seconds to start. Had all of the frame plating and armor put on in addition to long arms. Wired up 8 fog lights using relays. 3 relays, 3 switches all on their own circuit. Running them off of 8 gauge wire straight from battery. (It was running an amp before.) All of this work was done prior to going to Mountain City.
FYI, I am now also seeing oil blow by into the air box that wasn't there before.
My first guess is crank position sensor. The plug wires, cap and rotor all look new. Haven't pulled the plugs, but it idles just fine and it revs good as well. Seems to only happen when there is a load on the engine.
Any suggestions?
Any suggestions?
