XJ- looking to run fuel cell.
PhantomXJ1
Wake Forest
After numerous problems with stock fuel tank and fuel pump set up, its time to run a fuel cell. Figured a 12 gallon would be perfect for a weekend trail ride, and if I had to, put carry a gerry can. what ALL is needed to run a fuel cell? obviously I need to find a specific cell, cheap hopefully, but what else do I need to finish the project. fuel lines? which fuel pump? filter? vent lines? gas guage(not needed, but would be nice)? I've done a search on here, and Pirate, but all searches lead to people selling fuel cells, or we get threads that were started, but they were told to do searches, and those threads are gone. thanks for the info......
i think the part # for the pump is AZ e2000 search on NAXJA, it would be best to run a filter before and after the pump (not sure about #s)
or you could just locate the stock tank in side for about $12, if its an open top rig!
use a drag race cell the outlets are on bottom and can be bought with a sender as for fuel pump 90jeepman used a external pump for a ford e-350 van send him a pm for the part# he will be glad to help. i have access to race parts at wholesale $ if u need a cell i can get u a 16 gal. rci with sender for $135 and have it drop shiped to you. another important thing is does your eng. have a fuel press regulator and a return line? if so thats great u just t in the return before the pump or back to the cells extra outlet. if u dont have a regulator (late model)it used a regulator in tank on the fuel pump and the best way around that is with a aftermarket efi regulator if u need help with part# or inst. gave me a call 828-779-2242 chris
