well, two ways to pull it..
way #1 (right way): remove top radiator support, 4 nuts on front under lip, 3 bolts either side, and two nuts to hold on radiator, electric fan and fan shroud bolts. remove radiator support. then remove both nuts that hold the top AC condensor bracket, then turn bkts off to side, then lift up radiator and slide lower condensor bracket out and drop radiator back into holes in bottom, then cut condensor lines and remove condensor.
way #2: remove grille. grab favorite rotary cutting tool. cut upper and lower brackets, lines, and cut condensor in half to facilitate removal.
autozone sells a AC compressor bypass pulley. I leave the compressor in and put in a pressure switch and put in on board air(needs an inline oiler to keep the compressor alive)..
