shelby27604
- Jun 6, 2013
- Efland NC
Can anyone point me toward some 0" lift shackles (factory) that aren't the omix-ada / crown / doorman / moog / etc. type? I have been to a couple of different stores, and it looks like they are all likely made in the same factory. They are all stamped out of a single piece of metal and welded closed to hold the bushing. The problem is NONE of them are made correctly, where they should cradle the spring and have two parallel pieces, they are all shaped like a V, which results in a singular point of contact (metal to metal) spring to shackle. I had hoped torquing down the bolt/nut would true this up, but it didn't. I have tried to use my press to true these pieces, but it just skews the centerline alignment of the body bolt and the spring bolt.
I bought what I thought would be a good set of moog shackles which was apparently $65 pissed away.
I am looking to keep this XJ basically stock, I already have a HD set of crown springs in the rear, and they put the rear 1.5" up, looks like I will need to toss a larger isolator under the front springs once I get this sorted out.
