4x4fever New Member Joined Jul 5, 2005 Location abingdon,va Jan 31, 2009 #1 Got a 96 cherokee tranny keep shifting in and out of overdrive. Is this an electrical issue? Any tips to remedy are appreciated
rob92xj Member Joined May 8, 2005 Location fayetteville, nc Jan 31, 2009 #2 Check the TPS and have larger then stock tires been mounted? If so has it been regeared?
Ray VanBuren Well-Known Member Joined Jul 26, 2005 Location Shelby,NC Jan 31, 2009 #3 Does it do this in town or out on the highway? If this is the case, run in town in drive, not OD.
4x4fever New Member Joined Jul 5, 2005 Location abingdon,va Jan 31, 2009 #4 What's TPS? Its stock tires and does it on highway
rob92xj Member Joined May 8, 2005 Location fayetteville, nc Jan 31, 2009 #5 The Throttle Position Sensor, when they start going bad the trans acts funny. Does the speedo drop while driving if it does then you could have a speed sensor problem.
