xj windows
CT-E53
pitt county
ok so my windows stopped working unless you roll them down from the drivers door..anyone know and way to find the problem or how to fix this
what year is it?
I think its pretty common, mine do the same. You can bypass the windows lockout switch on the drivers side door, or clean up the contacts, I can't remember the details. Search JU or NAXJA.
i ahve the same thing on my 98 xj the windows only work from drivers control no where else. i was told by the deaership that it can be one of a few things, bad swicthes, cut wire( split) or a bad ground, it can be those only if you can still work the window from the drivers controls
mines a 97 xj...i think im going to tear it apart this weekend and see if it can be a easy fix if not its no big deal.
