LifeProof1
- Aug 31, 2012
- Jacksonville, NC
Firstly, thank you for your concern with my problem.
Situation, I currently have a XJ 44 rear end and am looking to set it up with the stock TJ suspension.
I have two issues that I'm trying to find the solution for.
Being that the tubes are thicker than a normal TJ 44, will TJ brackets have any problem being welded on?
Also I'm looking for some missing pieces, I have found lower control arm mounts and shock mounts through artec but I can't seem to find upper control arm mounts, sway bar mounts or a track bar mount that aren't for a 4 link or other heavy modifications.
Would anybody just suggest using the mounts from my D35?
Or does anyone know of suppliers that have the parts I'm looking for?
Thank you again,
Greg
Thank you again,
Greg
