Y-Link Steering Kit from Barnes4wd!
Barnes 4wd
Etowah NC
Y-Link Steering Kit
Sometimes its just not possible to fit crossover steering on your rig this is where our Y-link steering kit can save the day. If you are having to work around leaf springs, or if you only have the the two factory mounting locations on your steering knuckles our y-link kit is a great upgrade. This kit uses high quality, heavy duty GM 1 ton tie rod ends and 1.5" x 1/4" wall D.O.M., making your steering kit a worry free part of your build. All of the tube inserts have a hex machined on them to make steering adjustments a breeze, no more using a pipe wrench on the tubing you only need an open end wrench or an adjustable wrench. If you are planning to do a tie rod flip to the top of the knuckles, this kit with our tapered inserts or a reamer should be all the parts you need.
Here are the contents of the kit:
