YJ dana 30 with abs ???
88yjduck
Raleigh
I just picked up a dana 30 for my 88YJ. I think its from a 95 and I think it has ABS since it has a wire coming out with what looks like a 2 wire plug on the end. Can I just cut this off since mine didnt have ABS?
No YJ had ABS.
where is the wire coming out of?
Edit:Ermm, maybe I'm on crack cause the parts seem to hint for YJ's w/o ABS so that would imply there were YJ's with ABS?
If so, I'd think you could just cut the wires from both brakes? But I'm confused by YJ's with ABS, so ignore me :D
ABS was an option after 93. The vacume disconnect also has a electrical connector that I dont need.
the cable plugs into a connector on the back of the anchor plate
I'll try to get picture up
here is a pic.
