dewfamily
- Nov 4, 2011
- Clarendon,NC 28432
I have a 88 Wrangler with the 4.2. If the jeep sits for a period of time (week) it took for every to crank. There would be no gas in carb or line. I would have to turn the motor over for a while for the gas to reach the carb. I had the return line above the inlet. Then I replaced the carb and same thing. Question is, can I block off the return to eliminate that route or install a check valve in the line? I don't want to burn the starter up. Also, once cranked the motor sounds fine. After heated up, a small tick, tick, tick the nothing then another tick, tick. It is in the top, dont know if it is a lifter, valve. Doesn't seem like it is the valve cause it isn't steady. Any help would be greatly appreciated. thanks
