YJ in tank fuel pump options
Monkeynono
Mars Hill
So I and planning thr 383 sway with the holly sniper and would like to keep thr stock style fuel sending keeping the pump in tank. So I am loking for a pump that would fit the unit and give me about 60psi.
Any recommendations or help would be greatly appreciated
Stock ho 4.0 pump from a later gen yj should do it with an external regulator, the yj high output 4.0 runs at like 46psi stock regulated at the rail.
Plus it’s a drop in unit so you could get the pump only from a tj and swap it into the housing for the yj
