yj lift
They will help. but how tight did you tighten your shackle bolts? if you over tighten them they won't flex much at all
Also is your sway bar connected when you try and flex? do you have disconnects?
most people who get revolvers get rid of them after the first time they unload on them on a steep downhill. the feeling you are going flip over frontwards is not a good one. i have several friends who have tried them & didnt like them at all.
Add sway bar disco's, and remove 1 leaf from your packs, and it should work alot better. Also, make sure your spring, and shackle bolts are not over tightened.
Trash the trac bar in the rear. You won't know it's not there.
Check the main eye bolts as well. Loosen to 80 foot pounds on the main eye and 40 on the shackle. Or less if you feel necessary. Torque everything...
