yj soa stock springs vs waggy springs.
jeepyjman
Concord
if someone is not looking for extra lift does the 4 inches really help that much in wheeling? I already have the stock springs soa and am setting up my shocks and all that to finish it. I keep hearing about how good waggy springs perform. I was going to stretch the rear an inch by using the multi hole perch just to center the tire but was going to try running the stock springs. Is it worth the hassle? I still have to purchase boomerang shackles so I need to make a decisions on my springs because that effects the bolt i.d. btw I do not need the extra lift.
I would go with waggy springs. Not quite as soft as yjs so better on the street but the longer spring performs better offroad..
im running rubicon express reverse eyes up front and oem 6 leafs with a 1.5" add a leaf on the back. geat substitute for until you build ur traction bar
I'm in the same boat with my yj build stuck on if I want to stretch the rear. Do the waggy springs give more lift than the yj springs . I'd like the 2 or so inches of stretch with out anymore lift
they do. they give them 2" of lift. I ended up going with the rubicon express reverse eye springs.
