york clutch bearing
jeepyjman
Concord
anyone know how to replace a bearing in a york clutch? mine is making a super loud whine that make it sound like I have a blower. i have multiple other serp clutches but i have to run a weird offset clutch in order for my belt not to be thrown off. if I cannot find anyone my only other option is to oblong the holes on the bracket to bring the compressor forward.
its easy!
remove the bolt in the center of the clutch and their will be threads in center of the drive plate (cant remember size) you can use a large bolt to push the clutch off the shaft, it's tapered so it will be easy. then on the back side their will be a snap ring that holds the drive plate in the bearing remove it and if it wont separate from the bearing your going to have figure out how to press it apart without bending the pulley.
