doin a ifs brake conversion on a 81 toyota. jus wondering if the ifs calipers will bolt up to the front axle without any special brackets or modification? also will i need a newer master cylinder? thanks
The brake calipers will bolt right up. It depends on which calipers you got. Do they have a big and a small piston or two big pistons. A big and a small and you won't need a new master cyl. Two big ones and you will need one with a bigger bore. I'm pretty sure one out a tundra will work.
