Yota fuel PSI
bout 1 1/2 lbs. no more than 3 lbs.
mr gasket has a nice small regulator that will fit between the pump and carb nicely.
Mr Gasket has two options for cheap electric pumps. One is 1-3 psi and the other is 4-7 psi. On my Cruiser with the 2F I have the bigger one and then a pressure regulator so I could tune it for crawling. Thanks for the answer DAWGTOY.
