NCYota4x4 Well-Known Member Joined Mar 22, 2005 Location Kannapolis, NC Sep 14, 2007 #1 I got a 79 Yota and there is alot of play in the steering. Is there any way to tighten the steering box on these trucks?
rattlecanpaint Well-Known Member Joined Apr 18, 2005 Location Winston Salem Sep 14, 2007 #2 Loosen the big nut on the side of the box and turn the screw in the center. Make sure you tighten the nut back up or all the fluid will leak out.
rocktoy4me Active Member Joined Apr 16, 2005 Location Salisbury Sep 15, 2007 #3 if you still have the early style push-pull toy system, ditch it and go with a highsteer kit as soon as money allows. It will make a huge difference with the bigger tires and lift you are running. Seth
