Dan Fredrickson
- May 25, 2007
- Sacramento
We have been waiting patiently for way too long for these to be made but they are back in stock now so why not have a set (Pair) of 1 LH & 1 RH plus all the odds and ends it takes for 1 low price?
We are offering these from both of our Heim manufacturers, MWC makes a fine rod end from a High Tensile Alloy that we have now been using for more than 3 1/2 years without failure, they do squeak a bit but they aren't loose!
For the MWC set you get 2 High Tensile Alloy Rod Ends (1LH & 1 RH), 2 Weld in Bungs (1LH & 1RH), 4 Zink plated 1" to 3/4" Missalignment, and 2 Zink Plated Jam Nuts (1LH & 1 RH). All for only $90!
Our other option is the Heat Treated Chromoly Rod Ends from Rod End Supply, these have a 77,000lb load rating. Compare that to any of their competitors and feel secure that they will last! These come with the same setup as the MWC and we buy enough of them to be able to sell this set for only $135, thats for 2 top quality heims outfitted with everything you need to plug and play!
Depending on demand we should be able to keep these in stock for a much longer time this time around but I wouldn't be suprised if demand overtook us again but I have 250 LH & 300 RH coming every week for the rest of the year. We also have 10 employees working 6 days a week to get these out as quick as we can...
