tailgunnerex
- Nov 24, 2008
- fuquay varina
Just had a 93 XJ bite the dust on me, interior electrical fire. I want to take off the axles and install them on a 96 ZJ. I haven't looked into the front axle swap in detail yet but I assume the Dana 30 high pinion from the XJ would bolt right in, with maybe a driveshaft adjustment being in order due to the high pinion for low pinion change.
The rear axle is what I'm sweating......
The ZJZJ h a the stock Dana 44HD with the oversized aluminum housing, and the XJ has a standard Dana 44 out of an 87 XJ that had the tow package. I can't t find a manufacturer that make a kit with coil buckets and the other parts and pieces required to make this change. I want to keep the XJ axles as they both have recently been completely rebuilt and both have new 4.10 Dana Spicer gears and E-Lockers.
I've contacted Artec, East Coast Gear, 4Wheel Parts and one other axle adapter manufacturer, whose name evades me right now (age.....), but no luck.
Anyone successfully done this swap, on a street driven vehicle that is......?
