Not hard at all, remove the bumper first and than there will be 2 10mm bolts under each headlight assembly and one 10mm on the bottom middle. Than just the 10mm bolts on the top, and remove the grill. Take off temp sensor (if equip.), undue each headlight harness and it should come off as one big assembly..
