Zj steering question
HighrideCherokee94
King NC
Ive got a 94 zj lifted 5.5 inches with a 4.0 H.O. and i was wanting to change the tie rod drag link, basically the whole steering assembly with one form a v8 is that possiable to do with little modifications? will it pretty much bolt up?
so i can leave the drag link stock if i change the tie rod correct?
Yep. Your current drag link is the exact same as the ZJ V8 one. The tie rod on the V8 Zj is significantly beefier than your stock tie rod though and makes for a good low-budget upgrade. Its a solid bar vs, the thin hollow tube
