ZJ/TJ coil interchangability
93redzj
Albemarle
I know that the ZJ coils and XJ coils are interchangable for the front with the ZJ coils being stiffer. But are TJ coils interchangable with a ZJ? I wouldnt think the rears are just because the way they are designed but what about the fronts? If they will work, will they net the same amount of lift or less? For example, if I were to take 4.5" TJ coils and put them if the front of my ZJ, would it net me 4.5"? Thanks for any input.
the rears won't work at all because the TJ coils are of a wider diameter, thus won't work with standard ZJ buckets. The fronts will work and yield more or less the same amount of lift.
Don't a lot of people put the stock fronts in the back to gain 2" of lift. I know I have read that in the past. I know the springs are different diameters though.
