jeepinmatt
..l.
- Mar 24, 2005
- Stanley, NC
I had the 4L80E in my truck rebuilt after a major planetary failure. Now it runs in the 200-220F range with no load and no trailer under normal driving. If I keep the rpm's down (try to stay under 2000 everywhere), it will run more in the 150 range. But once it starts heating up, it doesn't cool down. It is equipped with the through the radiator cooler and the small factory external cooler. I just added an 11x11x3/4" cooler this weekend hoping it would make a difference, but it didn't really seem to (maybe 5 degrees). On hot days, it will start getting up in the 240-250 range around town, easy driving. I've verified the temps with a known good thermometer, and the gauge is correct.
There are no check engine lights, speedo works, torque converter is locking and unlocking appropriately, and the tranny shifts normally and correctly (except for a delayed shift from 2-3 when cold). I'm suspicious that its something pump related since higher rpms lead to higher temps, regardless of airflow on the coolers.
Anybody got any insight?
