wiring a trailer LED
wranglerrambler
oxford,nc
changing my camper trailer lights to some LED's. just need to know about the two wires from the old set to only one wire on the new set. its the amber side marker lights that are also turn indicators.
thats the original light. i assume one wire is turn signal and the other is the marker/running lights????
Yeah, if the original was a marker/ turn, you need an LED marker /turn. It should have two or three wires, depending whether or not it grounds through the body.
Or is that just a marker hot and ground? Can't tell what the photo is of...
Looks like a hot and a ground, need to ditch those scotch lock connectors also. they breed corrosion!
