Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Aight well I dropped the suspension lift on my truck a while ago, ie: cranked my torsion bars all the way down anyway I took it to my friends alignment shop and we set it up on the floor dial things, the castor zero'd out and the toe is set correct, etc. etc.
Well, the truck is aligned but here's the issue: I will be driving perfectly strait no issues at all smooth sailing. Then I'll stop to get gas get back on the road and all of a sudden its pulling to the right, stop again keep goin driving perfectly strait, then stop drive and it pulls right again.
I'm thinking something in the steering is loose, like one of the tie rod ends is just clanking in and out of place throwing off the toe or something. I jacked up both sides to check for balljoint loosness and both were good and tight no top to bottom play. Now my steering box itself has alot of play, but then agian it always has thats nothing new. So how do I go about zeroing in on the tie rod ends themselfs to see if they are bout worn out?
Or is there something else I'm missing?
Thanks
Thanks
