- Mar 13, 2005
- Raleigh, NC
So, after getting stuck in the I-77 backup last weekend, I've been looking around to try to better understanding of what all the options are.
I-77 at Fancy Gap is about 5% for 7 miles. This is not a bad grade, so long as the weather and traffic are cooperating.
US-52 is closed to trucks over eight tons southbound from Fancy Gap. The grade is four miles long. Based on some rough math on a topo map, portions of this are definitely in the 9-10% range, with some parts likely higher. Summit elevation is about 2900', base elevation is about 1600', but the bottom mile is pretty gradual. Most of the elevation drop happens in about a 2-3 mile stretch. It is two lanes up hill, one lane downhill, curvy, rough, with one or two emergency turn-outs on the downhill side.
US-58 at Stuart is 9% for 6 miles, two lanes, curvy, with no turn-outs. Uphill grade is in the westbound direction.
I-40 between Black Mountain and Old Fort is 6% for 5 miles. It is three lanes wide in both directions, but curvy. There are three emergency turn-outs on the eastbound (downhill) side.
US421 east of Boone is 8% for 4 miles. Uphill direction is westbound toward Boone. Two lanes in both directions, downhill truck speed limit of 30 mph. Mostly straight, but a few turns, particularly about halfway down. There is at least one emergency turn-out.
I-77 on Flat Top Mountain in WV (between Princeton and Beckley) is 5% for 5 miles. Uphill grade is in the NB direction. Two lanes downhill, three lanes uphill. Speed limit is 70mph. Grade is generally okay, but there are curves near the bottom (roughly MM20) that cause frequent accidents. The road flattens out until just past Princeton, where there is another 1.5mi long 5% section. This section also has three lanes on the uphill side. No emergency turn-outs on either section.
I-26 at Saluda, NC is posted as 6% grade for 3 miles. Uphill is in the westbound direction. Three lanes uphill, two lanes downhill. Truck speed limit is 55mph. The road is fairly straight with some wide, sweeping curves.
I-24 near Monteagle, TN averages over 6% over 3 miles on the downhill side. The interstate is separated, and westbound traffic uses 6 miles to gain the same 1000ft of elevation. The road is three lanes in both directions.
