Daniel Trail Block-off
Pretty sure that the logs we put across the right-hand spider trail at the first ledge on Daniel had a "Do Not Enter" sign nailed to them.
So, are they turning right up the hill before the logs or after?
At The top of the first ledge there is a trail to the right that people use to bypass the first ledge, it cuts off where the people usually stand
this is where im talking about,to the left you can see where people are going and in the pic the jeep is going down the first ledge for refernce
Right, but about a month ago, we put a couple of 12-18" dia logs across that path on the bottom side. Have the logs been moved, or are they going around them?
If they are going through there again, they had to move some heavy stuff, aggravating as hell to go out and fix it for someone to move it again, guess well have to put something bigger in there.
Yea all the logs you guys placed are still there it looks like no one has messed with them, but now there using the cut off I pictured to get passed the ledge
