ZachMan
New Member
- Aug 16, 2006
- Birmingham, AL
Only thing I am worried about is the mileage, its 140k miles, but looks to be a well cared for Jeep. Plus 4.0/ax-15s are cheap is something did happen
He will take $9,000:
This posting is for a 1999 TJ Sahara, 4.0, 5speed, 140K miles. 2nd owner, I've had it for 5 years now, since 43K miles. Very well maintained.
-NP231 w/Advance Adapters SYE, Tera 2Lo kit (lets you use 2wd low range in addition to 4low, 80k on case)
-Tom Wood's CV shaft
-High-pinion 30 front axle, Detroit locker, Big Daddy tie rod, 4.88 gears--regeared professionally less than 20K ago w/new seals, etc. Front driveshaft from a newer TJ just lengthened/balanced.
-Rubicon d44 rear axle swapped in, stock air locker w/stock pump (works perfect) and disc brakes, 4.88's--regeared same time as the front with new seals, etc.
-35" Super Swamper Trxus MT's on AR-767 rims (black), full size spare
-4" springs, 1" body lift, Old Man Emu nitro long travel shocks
-JKS front swaybar disconnects
-PSC rock rings f/r
-PSC rocker knockers
-M.O.R.E. sport cage
-Detours Manufacturing custom front bumper w/winch + light mounts, d-ring mounts
-Detours custom rear bumper w/tire carrier, hitch, d-ring mounts
-Instatrunk, 8" sub/amp w/Sony head unit and upgraded sound bar speakers
-Bestop bikini, windjammer, tonneau cover, barely used. Also Bestop trail cover
-Soft top, no leaks, but few scrapes and normal wear
-New Optima red top battery
-Warn m8000 winch, 3 or 4 pulls, two years old--looks almost new still
-Full hard doors
-RE adjustable arms all around except for Currie rear uppers
-Adjustable trac bars f/r
-ACF Gas tank skid (similar to Kilby's)
I just had the front ball joints done by a shop around 15K ago (all 4). Also just did the front wheel bearings at the same time. New power steering pump (8/1/06) and replaced the serpentine belt while I was at it. Always very well maintained, oil changed w/Mobil1 filter every 3K or 3 months. Redline synthetic oil in the tranny, synthetic in the f/r diffs, new lube in the tcase as well.
pics:
-PSC rock rings f/r
-Full hard doors
pics:
See if it jives with what he says.
