- Mar 20, 2005
- Morganton NC
Nice! I like
AS long as she calls me in from time to time for some porkin' ummm, I mean bacon, we'll be ok.
I printed that out so I can show it to her next time I see her. Now let's see... I have a few chores..........![]()
but I'd better help you with those chores , just in case!
Does Kelly still hate it?
Looks good, if you get any dead ones inside with no heads you got coons! Just be ready with close woods for predators. I've got a friend who unintentionally fattened up a coon for several months before killing him in a trap. He weighed 26.3 lbs.
Let me know if u want a rooster. I have two black roosters and only need one lol.
Sent from a hotel room
in a random po dunk town. now Free
So I know this is an old thread... but figured here was a good place vs a new thread. We are looking to get some chickens and I have some questions, as I am likely overthinking this whole deal.
I have read whats above....
- I am going to build a chicken house and then the coop around it. Is it better to have something that is mobile or can be moved around, or build a fenced area that stays constant but is a little bigger? I like my permanent. I think it gives them more space and you're not having to constantly move the tractor around.
- If its a permanent area, should you put posts in the ground with the fencing stapled to that, similar to what you would for other pets, or build a fence with posts and horizontal boards top and bottom that sits ontop the ground? Is there any reason to have the fence extend below the ground surface? Boards top, middle and bottom IMO. It helps when you're stretching the wire. You'll want to go below grade because if you have predators they can burrow under your fence. Just make note to staple your fence above the ground. I made that mistake and the wire I used rusted and I ended up going back and redoing it.
- I am guessing that the coop needs to have a covering over it, unless you are ok with them flying out? Clip their wings. Most know but if you don't, that just means take a pair of scissors and cut the ends of the feathers on one wing. You'll have to periodically go back and do it again since feathers get replaced. I thought 4-5' would be good but 8' was the better choice for me. You can put a cover on it to give them shade in the summer/fall and keep hawks out
- I read above that chicken wire will rot. What fencing is the preferred method? I've never replaced my chicken wire. The stuff I put below ground rusted in two but everything above ground is golden.
- If I fence a larger area, will I need to be able to get in a mow, or will the chickens keep the grass beat down? Chicken noob...They eat and scratch everything down to dirt. I've been recently throwing hay in there for them to kick around in. They also like grass clippings.
- If i start with peeps, how old do they need to get before putting them outside in the coop alone? I don't deal with chicks but I'd say 8-12 weeks and leave them in the coop with the door closed for a little while.
- I read somewhere about opening and closing the door to the house each night/morning. Is that necessary? Not necessary. It's mainly for protection from predators
- Do I need to put a light in there all the time or at all? Is it mainly for heat? You can manipulate their "day". By turning a light on in the coop it basically tricks them into thinking there's more sunlight or length to the day thus mo' eggs
- Should I plan to have a nesting box for each hen? I have three and they all use the same one for the most part, depending on the number of birds. My friend has 15 birds and they use two nest boxes even though he built a bunch.
- I read somewhere that some breed chickens were better at laying, some better at raising/sitting? What about eating when they get older, are some better than others? Most birds have a rating. It does depend on the breed. The rating system is based on the number of days per years it will lay. Golden Comets are some of the best layers. Some of the polish varieties suck a butt. As they get older, egg production will slow down. After about two years, it's time to start looking for some new ladies IMO.
I know there is alot of questions here, but figured there were enough folks around vs completely random internet ppl.
.No idea about the windows but I've had chickens for 5+ yrs and I don't see how they could pose an issue.Thanks for the info.
For the covering, Is there a netting that works best, or just use chicken wire?
Do you typically feed/water in the run vs coop?
Crazy question...
I've got some large tinted glass panels that I can't find a home for and thought about using them for the coop. Is there any downside to this? If they were on the roof I could see it getting really hot during the summer, but don't see much downside to using them as window?
