- Mar 13, 2005
- Raleigh, NC
To what extent is it considered "normal" to get exhaust fumes in the cab of a TJ?
Ours has a stock-style exhaust that exits in the normal place. It's cut a bit short now, but when we got it, it had an extended tip with a turn-down. Changing the exhaust hasn't changed the amount of fumes in the cab.
If the windows are rolled up and the top is on, little/no fumes get in. Maybe a whiff once in a while, but no big deal.
If one front window is down (even a little), lots of fumes in stop/go. Need to roll both windows all the way down and possibly turn on the fan, depending on how much stop/go, etc.
The soft top is about as tight as can be expected. There are gaps, but there are always going to be gaps.
The tailgate, however, is bent, and doesn't close very tightly. It is definitely not tight against the weather seal all the way around, so I'm guessing this is where a lot of the fumes are coming in.... but I don't want to go to the trouble of replacing the tailgate if the above behavior is "normal" in any way.
Thoughts?
Thoughts?
