family xj
- Feb 19, 2006
- Jacksonville NC
I just got my 89 5.0 put back together and I used some new 1.7 Pedastal roller rockers. For those that don't know the pedastal type rockers are non adjusting. Mine have some slop in them and they are tightened down to spec. Some back ground on the new build. I used the old hydaulic lifters as they were in excellent shape, same valves and springs just cleaned them up and had them reseated. Bored the motor .030 over and used a crank kit, has nothing to do with this and then used the old cam.
My question is How do I figure out what size push rods I need to buy since mine are obvously a little bit short?
I am not sure how to measure to get a longer push rod. This is pretty much the only alternative since I can't adjust them.
I did start the motor and it ran great but it is excessively noisy. Some please educate me.
Thanks
Doug
Thanks
Doug
The only time I've had to use the shims under the pedestals were when I shaved the heads for compression. And I'm not talking .005-.010", more like .030-.035".
