99 grand cherokee laredo. Key fob quit working now when i unlock the door with the key the alarm sounds. I have unhooked the battery for a week and when i reconnected it the alarm sounds. How can I kill it without a key fob? Thanks Scott
Nothing was broken that I could see. I can check with ohm meter when I get home. Do you know where the next connector is located from the door module connector? Also what kind of scanner can read the BCM? I bet my Harbor Freight Scan tool cannotYou need some way to read the data in the Body Control Module to see if the latch is indicating being open or closed. Did you inspect for broken wires in the door jamb harness?
Mine doesnt have a key lock at the tailgate.Key in the tailgate disables mine as well. It goes off everytime I reset the battery.
Yeah makes since i will order a new latch Monday. ThanksSorry, but all that I know of that will read what you need is a DRBIII. But admittedly, a DRB is all I ever used. There may be higher quality Snap On type scanners that would read also. The DRB will allow you to see what caused the last alarm set. i.e.- driver's door opened, liftgate latch, etc.
I don't want to roll the dice with your money, but it's always the driver's door disarm/ajar switch that causes this on WJs. The RKE use let's the passenger door module tell the theft alarm that the door was allowed open via remote. With your disarm/ajar switch being failed, the theft module isn't seeing a valid reason from the door module(s) for the door being open and thusly setting off the alarm. Make sense?
