3+ years in the making. Truck is at 95%. This is kind of an anti-build thread since most of the work is done. I will cross-post a thread with actual buildup pictures: http://www.noas4x4club.com/forum/viewtopic.php?f=32&t=6132 and I will post updates as I finish her up.
Specs:
Axles-
Front: High Pinion D60, 4.10s, ARB, Reid Cs, Chromo Inners, Spicers, AxleTech Portals, Wilwood Disc brakes.
Rear: 14B with Ballistic Shave, 4.10s, Detroit, pinion guard, AxleTech Portals, Wilwood disc brakes.
Driveline-
Rear: Custom SYE, 1350 jointed slip-shaft, transfer case disc parking brake.
Front: New slip-shaft with 1310 CV at transfer case, 1310 yoke on D60. Aluminum Nissan-Spicer adapter.
Transmission: Nissan D21 internals with 4.05:1 first gear swapped into D22 transmission case.
Transfer Case: Nissan TX-10A with Calmini 3.92:1 low-range.
Suspension-
Front:
3-link with Ballistic 3.0 Forged joints, 2.25" DOM links, Trackbar, 12" ORI STX Struts w/piggyback reservoirs
Bolt-on removable strut towers and strut tower brace
Rear: Spring-under with my 3" Alcan lift springs (rejuvenated by Alcan), Revolver shackles, 16" Fox 2.0 Air Shocks and custom in-wheelwell towers, Ruffstuff Traction bar. Front Spring hangers heavily gusseted.
Steering-
Forward-facing steering box ('78 F-150), ported for ram assist, flat pitman arm.
1.5" bore 9" stroke AGR ram
TC pump and remote reservoir
ORD 5-hole flat steering arms, ARP studs.
Wheels/Tires-
37x12.50R17 Maxxis Trepador Radials on Stazworks 17x10 Pattern "20" wheels w/8" BS
Body Mods-
1" Body lift for steering box and transfer case brake clearance
Replacement Bed trimmed for bumper clearance
Armor-
Sleeved frame for existing Shrockworks sliders, added gussets to slider mounts.
New belly skidplate UHMW Poly
Shrockworks fuel tank skid for Xterra modified for Frontier
Custom front and rear bumpers
Custom swing out tire carrier
Misc-
5-gallon air tank under bed
On board air with ARB compressor
Rear battery
Front M8274 winch w/contactor and in-cab controls
Rear M8000 winch w/contactor
Ford SuperDuty master cylinder, ABS deleted
Raised fuel tank 1"
Dimensions:
Weight: ~6100#
Height: 78"
Width: 80"
Height under axles (street pressure):16" front, 17" rear
Height under link mounts: 19"
Height under belly skids: 21"
Specs:
Axles-
Driveline-
Suspension-
Front:
Steering-
Wheels/Tires-
Body Mods-
Armor-
Misc-
Rear battery
Raised fuel tank 1"
Dimensions:
Weight: ~6100#
Height: 78"
Width: 80"
