- Feb 13, 2013
- Mayodan NC
Start from the begging ...
Purchased a 1997 jeep grand for the 4.0 out of it for a tj project...engine ran fine before the pull...
Put it in the tj 1998 model auto trans..
Engine started right up but had a skip with a weird rattle noise (could not determine from where....gave it gas....it cleared...
Idled for 10+ minutes
Put in reverse....shut off and would never start again. Will spin over fine and strong.
Tried everything...all sensors...injectors..plugs wires checked distributor coil ect. The jeep is getting the correct amount of fire, correct amount of fuel and compression is 130lbs on all cylinders but number one...it is 25lbs. BUT still should crank.
Timing is correct flywheel correct. Everything is new and good...
Changed the crank sensor and it finally threw a code (CPU cannot detect crank sensor) checked voltage on CPU to all three wires on crank sensor all are where they could be and I have tried 3 of them
I have taken it to the Chrysler dealership....no clue what it is...several local auto shops....no clue
.. jeep experts...no clue... I mean 30+ year mechanic vets....no clue...
It has everything it needs to run...
Now the snap on code reader when checking all sensors again said the injectors were 0.0 while spinning over...BUT I pulled the entire rail and they all work and pulsate as should..
This thing has me and 100 reputable mechanics beat....any help would be appreciated.
Thanks in advance!
Thanks in advance!
