McCracken
Logan Can't See This
- Jul 9, 2005
The first question is how much is acceptable?
The second question is how much do you have?
First a couple questions:
1) what type of joints are you using? Heims, Johnny joints, tractor links, heims have plastic races?
2) is it single/double triangulated and/or does it have pan hard bar?
3) if triangulated how much total angle of triangulation of uppers and lowers when viewed from above?
It felt stable even when I was cutting some pretty sweet donuts.There shouldn't be any side to side movement in the suspension. There may be a fair amount in the sidewall of the tires though so if you are just pushing it side to side on level ground that is probably what you are feeling. I know that is how mine is. If there is movement in the suspension side to side its not gonna drive so good. You would notice it right away.
#1 - Heims
#2 - Double but the lowers don't have a lot
#3 - I'll have to post a pic but I'd say the uppers are 30° and the lowers are maybe 15-20°
tops are roughly 28" and the lowers are 36"That doesn't look like it should have any play to speak of. How long are the links roughly? And are you sure it's not the holes in the brackets that may be sloppy?
Nick,
Are the jam nuts tight on the heims?
I've thought about this. Maybe I just need to tighten the piss out of the bolt and squeeze the mount some more.how much wider are your mounts vs the width of the joint?
are the jam nuts tight?
These are brand hammer new so I hope they're not loose alreadySomething is loose. You are on the right track. Jam nuts and link bolts will cause movement. Or slightly worn heims.
I am running Barnes brackets but with a 5/8" bolt hole. I didn't get the chance to check it out last night but I'm going to look again today.I added a spacer to my tabs in hopes that I wouldnt have to bent them back out after final welding to get the joint back in. Im hoping I dont have an issue like what your having.
What size bolts are you running? not 9/16"? The reason I ask is that some companies that make tabs make them for larger bolts than 9/16" Barnes is an example. If that is the case there are weld on reducers that are available.
