I somehow doubt that few, if anyone, is running that kind of combination to comment. Tons, 49s, and a 4-cylinder? To just use some math, that gear ratio is 25% deeper than what you had, so your engine will turn 25% more RPM at any speed given the same tire size. However, I am guessing you are also going up in tire size, so the math needs to be adjusted back down for that. And if you go to larger tires that means they weigh more and take more energy to spin, plus your new axles are a bit heavier than what came out, so that also makes the truck less peppy.
To give you some sort of relative comparison, I went from 4.63s with 32" tires to 6.15 with 37" tires. Straight math said I needed about a 5.80 ratio to be "even". But I went to a significantly heavier wheel and tire combination (I think I added 60# per corner) and I put a 60/14 combo with portal boxes under the truck. I increased the weight almost a TON (yes, 2000#) and so the truck feels winded anyway and gets terrible fuel mileage. I will also note that I swapped out the transmission to one with shorter ratios in all gears except 4th to get more RPM out of the engine (about 10%). Again, she still drives slow. And I have a V6 with ~170Hp/200lb-ft at the crank.
