woodgo
- Nov 9, 2006
- CLAREMONT, NC
I just recently installed a set of 33x12.50x15 Goodyear MTR's, and so far, they are the worst riding tires I've ever had.
Of course they were balanced before bolt-up, and felt fine at low speed. At 40 to 46 mph, I thought they would vibrate the wheel out of my hands. Faster speeds seemed smoother, but the vibrations may have become closer together so that it just felt smoother.
Back to the shop I went; they took each tire off and re-balanced them which made practically no difference.
Well, I thought, "It's time for a new stabilizer." But a new Rancho didn't help at all.
So then I took the tires to a different tire shop that used an on-vehicle tire shaver to true them round. When that made very little difference, I went back to that shop for more re-balancing with little improvement
The violent shake has lessoned, but it's still annoying. Is it a problem with these tires?
While driving around to diagnose the shaking, I discovered a definite and disturbing pull to the right that had not been there prior to the tire purchase. "Ah ha, I need an alignment," I said to myself. After a visit to my favorite alignment rack, I could tell no difference; if I turn loose of the wheel, the pull will put me in the right highway ditch.
Now I swap right and left front tires--NADA; I check drag on all the brake shoes--NADA.
Is there anything about the MTR's that would not only cause unusual vibration but also cause tracking problems?
I kind'a think I made a bad choice in replacement tires.
Anybody have any help?
