Picked up a '91 XJ, 4.0, auto, 4wd. It didn't run since December. It started cutting off but started back and then finally died totally and has been parked since. No fuel, no spark. All other electrical works. Gas gauge won't register after I put 5 gallons in but the low fuel light went out after I added a couple gallons. Other gauges work. Fuel pump does not cycle when switch is turned on and there's no fuel pressure at any time. Wire to fuel pump shows 6 volts when key is in on position.
Fuel pump has been replaced for sure and other issues have been said to have been chased but there's no evidence of it. major and minor fuses are good, checked with meter. Relays have been swapped to known working systems and continue to work.
We were on the trail of the Crank Sensor being bad but ours was slightly different than what the book showed so the meter tests were not conclusive but we replaced it anyway since we had already gotten it.
Did not have time to check coil.
Am considering finding used ECM at Pull A Part to plug in and see if that helps.
I've read a LOT of stuff on forums but am overwhelmed at this point so am asking for answers and opinions.
Please tell me what you think.
