4RunnerLVR86
New Member
- Oct 24, 2006
- Monroe, NC
I got a 85 toyota pickup and I want to lift it. What is teh best lift I can get for it but still cheap. Thanks
X2toy rears up front, make your own front hanger, 63" chevy's in the rear. i came out less that 200$ for all that, with shocks and all. Just a little work... ~3-6 inches of lift, according to how you want/build your hanger, & how long your shakles are. Search pirate4x4.com everything you need to do this is here
http://pirate4x4.com/forum/showthread.php?t=459180
My question is when using the rears up front, what do you do about the sag in the rear springs. Mine are almost flat. Do you have them re-arched or just throw 'em on there?
really?I had good luck doing the helper-coil trick, known on 4x4wire as zok-coils.
Basically slip some stock TJ coils between the upper bump stops and the leaf spring. I netted about 2" this way and it ride much better.
Here's an example:
http://www.gearinstalls.com/dc.htm
a pic of mine drooping before I put the tire and weight back on it:
I, too am thinking of using some tax refund money to lift my '84. My question is when using the rears up front, what do you do about the sag in the rear springs. Mine are almost flat. Do you have them re-arched or just throw 'em on there?
really?
I don't have any other springs laying around, but junk yards are close. How much should it deflect with my light 130 lbs on it? And yea, hi-steer is a must so I don't drive it in the ditch the first time I have to slame the brakes. Do you need an IFS steering pump too or will my old one work? (Know I need the box.)mix them up with other rears/ any other springs you have, or add-aleafs...
by usuing your body weight and laying the leafsprings upside down, you can stand on each seperate spring to measure the deflection... kind of a redneck way of calc. spring wt... and build your own pack... worked for me![]()
also...x2 on highsteer, i made my own using the push/pull, got the idea from MandM offroad... and just got a used ifs box, and pump from the junkyard.
