The answer is, the coil.
I tested the pickup inside the dist ...600 ohms (ok)
I tested the coil , 0 ohms pri, 8k ohms sec.... Hmmm
no way to test the electronic ignition box.....so
I bought an electronic ignition box, a MSD blaster coil
, and a OEM coil.
when I got home I measured the new OEM coil , 1.2 ohms pri, 8k ohms sec (ok)
I installed the MSD blaster coil, and started up the Jeep (yay)
it ran for about 5 seconds and died. (ohoh)
so I installed the new OEM coil, and the new electronic ignition box. Runs like a charm
the MSD blaster coil only has about .6 ohms in the primary. It likely finished off the old electronic ignition box, but I didn't want to take a chance with the new box, so I decided to use the new OEM coil and "just wheel it"
thanks for the help guys,
Steve
