87GMCJimmy
- Apr 24, 2007
- Mint Hill, NC
Due to my truck's (comparatively) light rearend and its loooong wheelbase, I have several times found myself in situations where a side pull was necessary. I would like to mount a winch to the rear of my truck but would like to figure out a way to make the winch work for side pulls. (I do not recall ever being in a straight backward winching self recovery situation with the truck though, I have had times when a rear facing winch would be handy for recovering others!
Obviously, a 90 degree side pull is not ideal for a straight mounted winch.
3 winches would solve this (straight, right and left) but would be completely impractical.
Having somebody behind me that has a winch would also solve the problem (as it has in the past) but, constantly depending on others is not a good solution.
I have found myself needing to pull froward with front mount winch whilst simultaneously having another rig's winch pull the rear of my truck sideways so, a straight out the back line with pulley blocks setup to redirect to a side pull would be putting the work of my winches partially at odds with each other.
My initial thought was to build a slip-plate style winch mount. But, given the dirt/dust/mud/water the mount will near constantly be exposed to,I wonder if this is the best approach? My second thought is whether this type of setup would put the cable routing potentially in conflict with my rear leaf springs. Given these questions, this doesn't seem practical.
So, what about positioning the winch deeply recessed under the rear of the truck, and running a removable center roller to redirect the line 90 degrees out to mini fairleads at the two sides of the frame in areas where the cable couldn't possibly hit the leafsprings? That way the 90 degree pull would be a straight pull as far as the winch itself is concerned. Then, if a straight pull is needed, the center roller could be removed and the cable routed out a full size roller fairlead at the face of the bumper.
^ all this could be easily viewed/performed without crawling under the truck by cutting an access panel in the bed of the truck. (if the bed was full of course this could be done by crawling under but, that would be best avoided)
Bear in mind, the 90 degree side pull capability would not be used for the recovery of other vehicles and would never see full vehicle weight loading as it would only be used under limited traction conditions. (such as when the rear of the truck slides down a slippery clay side hill into a tree or when I had to purposely break traction so the truck could be pulled sideways in order to make a turn that was too tight for my truck's turning radius) Also, I don't anticipate the 90 degree pulls to be more than about 20' at maximum.
Anybody had to come up with something along these lines? Thoughts?
