McCracken
Logan Can't See This
- Jul 9, 2005
Ok, so I've been remodeling the bathroom at the house. We picked out the tile and we laid it down last Saturday. I asked my wife when we were at Lowe's to get the color grout she wanted. When I went to mix it up I put in the water and got a good consistency before applying it. After about 30 minutes the shit started locking down on me. To the point where I couldn't get it out of the bucket. I went and grabbed the bag and found out she bought rapid set mix
Shame on me for not looking and just going with it. Anyway, I salvaged the job with some scrapers and sponge work and believe it or not it came out pretty good. So to the problem/issue... because of the cuts I ended up with a pretty fat grout line near the tub. I figured I could run a piece of molding along the bottom and take up some of the line and make it look good. The problem is that the grout is humped up and set. I was focused on the floor and got it right but forgot to address the tub base. So here's the dilemma. I need to flatten this area out so the molding will fit.
So as the internet so eloquently puts it, "wat do?" I tried sanding it down with some 80 grit and that didn't happen. How can I flatten the area without fubarring the rest of the tile and tub? As you can see, the grout line at the tub is fat.
Shame on me for not looking and just going with it. Anyway, I salvaged the job with some scrapers and sponge work and believe it or not it came out pretty good. So to the problem/issue... because of the cuts I ended up with a pretty fat grout line near the tub. I figured I could run a piece of molding along the bottom and take up some of the line and make it look good. The problem is that the grout is humped up and set. I was focused on the floor and got it right but forgot to address the tub base. So here's the dilemma. I need to flatten this area out so the molding will fit.So as the internet so eloquently puts it, "wat do?" I tried sanding it down with some 80 grit and that didn't happen. How can I flatten the area without fubarring the rest of the tile and tub? As you can see, the grout line at the tub is fat.
....oscillating tool with a grout blade or if your molding will cover it you could notch/whittle/sand/cut out the back of it.
but hey dip shit cut the back edge of the trim at an angle slap it in and call it done.
