WARRIORWELDING
Owner opperator Of WarriorWelding LLC.
- Jan 6, 2008
- Chillin, Hwy 64 Mocksville NC
Mini splits I have considered, but the old home is nearly 1800 square on one level. And high ceilings. Would they be economical. I understood they were small space oriented.Have you thought about mini-splits...can easily do some zones that way, as you live in or renovate parts of the house.
Do you have the wood source to feed an outside boiler? How about pellets? They have them now with a hopper and screw feed, iirc, will last a couple of days at least.
I think gutting too. Is this sort of stacked on air flowing through several devices common??? I can't see how it's efficient at all.I would think the simplest thing to do is gut it all out. Put a heatpump in it and add an outdoor stove to the system. Basically free heat in the winter and then you have ac in summer
Outdoor stoves are basically outdoor boilers. You but a radiator inside the box for your heatpump. As long as the radiator is hotter then what is needed the heatpump won't turn on but the fan will turn on and circulate the air threw the house. That may not be explained right I'm looking for a pictureI think gutting too. Is this sort of stacked on air flowing through several devices common??? I can't see how it's efficient at all.
You and my mother in law must be kin. Trimming that mess 3 times a year is something I could spend my time doing anything else. I have to use the loader and raise it all the way up like a portable scaffold. If it doesn't get trimmed quaint gonna be the little house of horror.You should post a pic or two of your run down old timey shack. Its beautiful. I've always loved that old house, especially the ivey.
I have one of those, it's listed in the broken.....Outdoor stoves are basically outdoor boilers. You but a radiator inside the box for your heatpump. As long as the radiator is hotter then what is needed the heatpump won't turn on but the fan will turn on and circulate the air threw the house. That may not be explained right I'm looking for a picture
See post 2 and 4. It's also old tired and ready to implode.
I see now. I still say you'll end up cheaper in the long run taking it all out and putting a modern heatpump system in.See post 2 and 4. It's also old tired and ready to implode.
Honest the front used to have a Italian styled front porch grotto with hand laid patio brick.
Same as the path in the side yard that was to the hand dug well.
still, pics worth a thousand words.You could add mini split systems to the part of the house that isn't heated or cooled currently. And if wanted to return to all original later there would only be a couple 2-3" holes to fix in the walls instead of vent holes in the floors or ceilings
