snakester14
Active Member
- Nov 3, 2006
- Greenville
so the other day I put my Stock TJ in for a 4 inch suspension lift by rough country. They installed it and called me back and told me I had to order a different drive shaft and a yoke slip eliminater.
I understand that the stock drive shaft didn't fit and I needed a new one but I don't understand the why a yoke slip eliminater was needed and what does it do?
thanks,
Jake
thanks,
Jake
(Check the vendor specials section on here)
] ) is often recommended to keep the transfer case in the factory position - as mentioned above, by shortening the output yoke on the transfer case (xfer case), it accomodates a longer driveshaft which, in turn, has less angle in relation to the pinion yoke on the rear axle. Too much angle and you get vibes or even drieshaft failure.
