John Godwin
New Member
- Jun 10, 2017
- Advance
I only drive my Renegade once a month. The first crank requires a lot of turning over for the mechanical fuel pump to deliver fuel to the Carb. After first start I have no trouble starting. I have tried pouring a tad bit of gas in carb and she fires up nicely. Any thoughts of how I could install an electric fuel pump to prime the system? My mechanical pump seems to work great after first start. My fly wheel doesn't have the best teeth any more so I don't want to spin those gears any more than I have to. She is not a daily driver. She is my Mountain Jeep. Thanks for any help. My thoughts were to install an electric pump between the mechanical pump and the Carb, but I am not sure if the elec - pump could pull fuel through a mechanical pump prior to starting to prime the carb. Then once started could the mechanical pump push fuel through the electric pump once I stopped powering the primer electric pump. Thanks again. John.
