skyhighZJ
- May 31, 2012
- Aberdeen, NC.
You can buy a USB interface cable and get whatever you want off of it for cheap (roughly $20), or put into an enclosure and make it more permanent for more money. Either way, it will be an interface/adapter board and a wall wart power supply to power the drive.
Even though it was formatted to run as the hard drive for a dell I can put it in an enclosure or get the interface cord and another kind of computer and it will recognize it?
You are fine folks that never cease to amaze. Thank you. I have been frying out cause there are 7 deployments worth of memories on this thing.
My thoughts were to buy another quality drive, transfer the files I want to save and stash it away in a safe place. The movies and music will be put on another drive for common usage.You might also want to buy another external drive (Western digital passport for $50 or whatever) to back up all those files to a another location if they're that valuable to you. A drive that old that's been through a lot of abuse may not last forever, and then things really get difficult.
You can simply buy something like this if its sata. If its IDE you will have to find a different one.
Unless PCs have changed (i prefer linux), you will then need to map the drive (assign it a number) and then it will show up for you. Their are simple instructables online for this. The problem you will run into is the Windows SAM (its all password protected), so....
usually i prefer to boot up a RAM disc DSL (damn small linux) or PartedMagic, and then I can access it straight forward and bypass passwords, grab files off and onto a USB or even recovery the drive if files were deleted.
Now that I have verified that I don't understand Chinese.... what does this mean??
In Windows if you plug the drive in to either a usb sata adapter or a free sata plug it will come up in my computer and if using usb, it will ask what you want to do when it's connected. Open to view files and copy away.
Never had that issue myself.. if you're logged in as admin shouldn't make any difference... Now if the files were encrypted under the old user, you're screwed unless you boot off the old drive as far as I know.Yes but there should be an issue with copying files located under a user (my docs, my pics, etc)
And simply buy beer for your computer guru friend..Ignore everything he posted in this thread.
Borrowed an enclosure from a friend till my docking station arrives. I have been able to look at the information (pics and such). I tried plugging the drive into my PS3 to access the movies and no dice. It doesn't even populate on the PS3 main screen. Fwiw on the dell HD it was an admin profile and login and it popped right up on the screen as e:drive then :user then choose appropriate file. Seems too easy. I'm going to get another hdd and copy the movies and see if I can pull them up to watch. I don't have or believe in paying for cable of any sort so we watch movies every once in a great whil around here. If it's a no go then so be it but at least it seems I'm able to access the pics and that's what I care about the most.
