Van-go
Not an old man
- Dec 11, 2014
- Greensboro
I just replaced the axle housing for my Ford 9 inch because I bent the old housing.
It is a stock semi float unit.
I'm using my same shafts, and the bearing races are pressed all the way in.
I'm not getting quite as much spline engagement as I used to.
See picture.
Any ideas why?
You can see the two different wear marks.
It is about the same difference on each side as far as old versus new.
The housing is measured the same from flange to flange.
See picture.
Any ideas why?
