marty79
- Dec 2, 2015
- Newton, NC
(making the mounts as we speak)
No I'm making the brackets but not on the bodySounds like you've already made your decision.
No just a regular rear shaft. With smaller lift than I had and pinion set at 6degrees roughly, regular driveshaft will do great..at ride height it's practically close to stock angleAlso if you're running a double cardon driveshaft you want your upper to be longer than your lowers.
I'm with you on this. I've about thrown some leafs back under it about 10times now lol but I wanna be able to say I'm capable of doing this.Some times you just have to say "fuck it" and actually build the thing otherwise you will run the numbers ad infinitum and your truck will sit on jackstands for eternity. Besides, just like politics no one really agrees on the "magic number" anyway.
Rear, I'm hoping to finalize it and put it together finally. Seems I'm close "enough"??Is that the front or rear?
Yes it is much much easier to get the good numbers I have with the 3link rather than the 4 that's why I tried both and stuck with the 3link.Are u doing a 3 link rear?
so guys this 3link setup looks really good as far as numbers..what do you guys think. I'm home now and ready to get back at it but wanna make sure you guys agree with this setup. Thank you
Ah gotcha. I'm trying my best. Admit patience is wearing on me lol, ready to get rolling@marty79 see in bold and underline. this is what i "liked" about the post
4link was just way too much work/cutting into body and floor boards . 3link allows me to make it all work with current setup
I still had to get my wheelbase even so driver side came back in 1/2" so it's all good. That was quick pics after both in there. I tend to do that rather than wait till it's all even/clean/adjusted lolHow much thread engagement do you have on those heims?
I get overly excited lolNo problem man... Just making sure. Hate to see someone else overlook that and end up wrecking everything attached to the axle
Ok guys so will this work. I have upper links same spot works for either setup so figure do 4link and no track bar.
Are the #s good enough, thank you
Thank youI see a few issue you could improve with little change.
Lower your AS 7-10%.
Shorten the uppers a little. They are a couple inches too long for the AS not to increase a bunch during droop.
Hard to say how much as you aren’t looking at the geometry as the suspension cycles.
I guess it’s too late to triangulate the lowers some, this would help the roll axis angle and decrease some rear steer when articulating.
Make chassis side mounts have 3 holes at 1” increments vertically. Use the dimension you end with in the calculator as your center hole.
What's that mount welded to?Well it has begun lol..
View attachment 264588 View attachment 264589 View attachment 264590 View attachment 264591
