Charles Smith
smitty1371
- Sep 28, 2017
- ellerbe nc
can anyone explain the purpose for boomerang shackles? Are they just a marketing thing to sell parts? If they do serve a purpose how should they be oriented long side up or down?
They are made for clearance issues. Like a shackle contacting the body or a body mount on full compression. I don' see how shape would effect shackle inversion.
Ahh the cross bolt, that makes sense.![]()
The cross bolt would contact the frame stopping shackle movement is how I believe they would combat shackle inversion.
Or you could set your springs up with a decent shackle angle![]()
That would be my approach.Or you could set your springs up with a decent shackle angle![]()
Also didn't consider this. I guess I'm stuck in the toyota world, where the shackle is on the back side of the sping and less of an issue. And now that you mention this I've seen that happen on a yj once or twice.It's for when you smack the shackle into a rock or some other immovable object and it tries to forcefully invert the shackle and bend the spring.
