RatLabGuy
- May 18, 2005
- Churchville, MD
Its that time of year again when the top comes off the old 4Runner, and I cuss and bitch about the process of getting it on and off.
I've done the ratchet strap method previously, but I'm ready for something to really get it lifted up high and out of the way.
Curious what kind of contraptions people have used.
I'm thinking of either getting 2 sets of these double-pulley systems, or maybe just buy 4 separate block/tackle sets, and running a single line through both sets, then using a HF electric winch ($50 on sale) to pull it up and down. Then I'll also conveniently have the winch mounted so I could use it for lifting other things like the mower front end etc.
https://www.amazon.com/Extreme-Max-...rd_wg=kDxxy&psc=1&refRID=SR6KNKBK1RP3J7J2G9RS
The thing I can't wrap my head around is how/whether all 4 would stay balanced/pull up at the same rate if the load were not perfectly evenly distributed (which it isn't, its definitely heavier in the back). In other words if I use a single rope through all 4, is there anything preventing the ones with the least weight under them from just lifting up first?
Clearly there is a physics lesson I skipped
All joking aside...
) is all you need!
